Issues with Updating Masked-Area-Only Histogram in Conditional Curve Transformation
Posted: January 24th, 2026, 11:13 am
In the Conditional Curve Transformation, the Masked-Area-Only histogram does not update if the "Display Input" radio button is selected.
This issue appears both when updating the mask and changing the y or x axis selection.
To reproduce:
1. Run PWP 8.0.546
2. Add the Color Chart Test Pattern
3. Add the Conditional Curve Transformation
4. Select the Display Input radio button
5. Select the Display Histogram on Masked Area Only radio button
6. Create new mask from the mask thumbnail next to the Amount slider
7. In the Mask window, click the Mask Left Half button
8. Note that the histogram does not update. (Also, repeatedly click the Invert Mask button and note no histogram updates.)
9. Also note that if the Display Input radio button is set, updates to the Y-Axis and X-Axis pull-down menus that should alter the masked histogram do not.
To reproduce:
1. Run PWP 8.0.546
