Problem with Warp Transformation Reset
Posted: January 17th, 2026, 7:57 am
If the Warp transformation's horizontal constraint is enabled and the transformation is reset, the control-point constraint radio button is not reset and becomes out of sync with the control-point behavior.
To reproduce the problem:
1. Run PWP 8.0.543
2. Add Checkerboard test pattern
3. Add Warp transformation
4. Select the horizontal constraint radio button
5. Note that control-point movement is constrained horizontally
6. Select Reset from the Gear menu
7. Note that the horizontal constraint radio button is still selected but now out of sync with behavior
1. Run PWP 8.0.543
