Update Available - Version 8.0.540
Posted: December 13th, 2025, 9:47 am
An update is available to Version 8.0.540 (13-Dec-2025)
Updated from Visual Studio 2022 to Visual Studio 2026 development environment.
Added two new items to the settings menus of all transformations: Set (or Reset) Initial Window Placement. When you create or edit a transformation, its dialog box is normally positioned according to File Preferences (Initial Dialog Position). These new commands let you change the initial position and size of transformation dialog boxes to match the current transformation dialog box. A change to the current transformation affects all current or future transformations of the same type. For example, if you set the initial window placement for a Crop transformation, then the next time you create or open a Crop transformation, the new position and size are applied.
