Update Available - Version 8.0.534
An update is available to Version 8.0.534 (20-Oct-2025)
Corrected documentation and program messages to indicate the correct key combination for canceling a transformation or script is Ctrl+Alt and not Shift+Alt.
Fixed problem of status message not being erased in some cases when canceling the loading of a script file.
When canceling loading a script via Ctrl+Alt, you now have the option of bypassing the canceled transformation and continuing with it in an error state or terminating the script. When you subsequently edit the bypassed transformation, it is recalculated and the error is cleared.
Fixed several problems with editing transformations that are in an error state.
Export transformation: fixed problems with changes to output image not always propagating to downstream transformations, and a problem with certain text changes not being recognized if the text delay timer did not have a chance to time out.
