Update Available - Version 8.0.517
Posted: July 3rd, 2025, 12:57 pm
An update is available to Version 8.0.517 (3-Jul-2025)
Resize transformation: fixed problems with incorrect dimensions when setting the long or short side and switching between landscape and portrait input images.
Changed the way scripts are canceled. The dialog box with the Cancel Script button is gone -- now, to abort a script without waiting for it to run all the way to completion, press and hold the Esc key until the script is canceled. This also fixes the problems of the screen going black during script loading and the Cancel Script dialog box covering images as they load.
All transformations with Amount controls: fixed problem with loading or reloading previous settings not properly clearing all the previous mask settings if an initial mask image was selected.
Added a warning when loading a settings file if the transformation it was generated by depended on other mask images or auxiliary inputs.
