Update Available - Version 8.0.483
An update is available to Version 8.0.483 (15-Feb-2025)
Tint transformation: added a Reference Image setting. If you specify a color reference image, it is used to define the color line by setting its color at each of 17 brightness levels to the average color of the pixels of that brightness in the reference image. See the help file or Transformations.pdf for an example of how you can use this to transfer some of the feel of the reference image to the input image.
Crop transformation: added an optional overlay on the input image that highlights the area outside of the cropping rectangle. You can adjust the transparency and color of the overlay, similar to mask overlays. If you don’t want an overlay, set the transparency to 100% and it will work as before.
Re: Update Available - Version 8.0.483
Two very cool updates... except I don't think the crop mask tool is working as intended:
The masked area jumps around all over the place when the crop selection box is altered.
OK, I see the problem. It works OK if the entire image fits on the screen at 1:1 which is the case I was testing here.
For the time being, just leave the transparency at 100% until I can fix the overlay code.
