Update Available - Version 8.0.469
Posted: December 13th, 2024, 8:35 am
An update is available to Version 8.0.469 (13-Dec-2024)
Raw Develop transformation: Reworked the way lens profiles work. Picture Window now includes a copy of the LensFun database which provides information about many different lenses and camera bodies. Using this open source database you can apply distortion, vignetting and chromatic aberration corrections to raw files. While not definitive, the database is updated from time to time with new cameras and lenses. The command to create lens profiles has been removed from the File menu and old lens profiles are no longer supported. Before using the Raw Develop transformation, it is recommended that you delete the prior contents of your Lens Profiles folder, normally located at the following location: Documents\Picture Window Pro\Lens Profiles.
Selective Color Correction: adjusted the controls to reduce the minimum dialog box size.
Image Browser: there are now 2 buttons for show/hide thumbnails. If no images are selected, they show or hide all thumbnails. If any images are selected, only the selected ones are affected. This lets you show or hide individual thumbnails.
