Update Available - Version 8.0.466
An update is available to Version 8.0.466 (13-Nov-2024)
Moved the Disable Breakpoints checkbox to the Batch Progress window so it is active during breakpoints.
Process or Skip no longer leaves the File Open transformation dialog box open. It also adjusts the image browser to display the current image. Removed Terminate Batch and Disable Breakpoints controls from Process or Skip dialog box as these are redundant with the controls in the Batch Progress window. The main image area is now active while the Process or Skip dialog box is displayed so you can zoom or scroll the image normally. The main menu and image browser are disabled however.
Breakpoints are no longer allowed on transformations that have no settings (e.g. Process or Skip and certain test patterns).
Slide Show transformation: added support to left and right arrow and escape keys. Slide show no longer terminates at the end – you need to shut it down manually by clicking anywhere on the screen or pressing Esc.
