Test mode for batch processing : user interface
Usually I keep the Batch progress popup window minimized, as it sometimmes occults parts of the screen.
When test mode dialog pops up, the image displayed in the preview part of the screen is the previous image, usually at an export transformation step.
Issues
1. When the Batch progress popup window is minimized, the image under "test", which is to be processed or skipped, is not shown neither in the main image area nor in the popup itself.
2. The vignette of the next image displayed in the batch progress popup is not always large enough to allow the user to make a good "culling" assessment.
Suggestions
Bring up a large display of the image being "tested" with the test mode dialog popup. A large image in the main image area for zooming and scrolling would be convenient.
Re: Test mode for batch processing : user interface
Updating the main image area causes other problems, but for the next release I made the Batch Status window resizable to you can enlarge the thumbnail if necessary.
Would it possible to include the resizable image thumbnail in the Test popup dialog ?
Should be possible.
