version numbers
version numbers
It seems that if an image originates from a paste operation rather than a file open operation, version numbers are not generated when saving. Is this intended?
Re: version numbers
When you paste from the clipboard as opposed to opening a file from a folder, there is no "original pathname" or other clue as to what the default name of the saved file should be. Do you have a suggestion for how this should work differently?
Re: version numbers
Possibly append v1 to whatever name the user provides, and for subsequent saves, increment the version number.
Re: version numbers
It's trickier than that, but I'll see if I can come up with something that works.
