PWP 5.0.1.9 - Monitor Curves - not selectable when printing?
mark_hay
Post by mark_hay »
Hi Kiril
I have installed the latest PWP version on my XP SP3 PC.
I wanted to use Inverse Monitor Profiles when printing. (First time I needed to do this.)
I see the check box on both Print and Print Album dialog boxes.
But I see no drop down to select the relevant curve.
Could you please point me in the right direction for this?
(Simply checking the box does not seem to use the current open monitor curve.)
Thanks, Mark.
Re: PWP 5.0.1.9 - Monitor Curves - not selectable when printing?
The Inverse Monitor Curve checkbox uses the current monitor curve. To determine what the current monitor curve is or to load a different curve, use the File/Monitor Curves function before printing.
