Update Available - Version 8.0.433
An update is available to Version 8.0.433 (2-Jun-2024)
Warp Transformation: fixed problem with Batch Reset flag not being saved correctly in command lines so the setting was not correctly restored when editing or executing the transformation. Fixed small error in computation of output image size and area.
Crop Transformation: fixed inconsistency between the Reset Crop Box to Entire Image command in the right-click menu and the tool bar button with the same function. Fixed problem of crop box overlay not being erased correctly when only the input image was being displayed.
Added the F5 keyboard shortcut to simulate selecting Reset from the Settings Menu for the currently open transformation dialog box, if any.
Fixed problems with zooming and scrolling the main image area when a transformation was in progress, the preview image was being displayed by itself and an auxiliary input image was selected.
Clone Tool: fixed problem with Undo not resetting the Source Image control correctly.
