White balance
Posted: February 17th, 2024, 12:11 pm
I have been taking a bunch of photos of an object against, and backlit by, a white light panel. As a result, there is a lot of bright background, although the exposure is such that the background is not blown out. Because the light panel is not meant for photography, it has a wee bit of a colour cast.
The final image is a compilation of a number of these images, composited together (using 50% opacity each time, long process, longer explanation).
Once the final image is rendered, I do a white balance, using auto first, then I do it again, manually choosing an area within the background. Settings are 5 x 5 and Low White Threshold.
However, regardless of whether or not, I use auto or manually choosing a background location to sample, the result is the background shows an obvious, albeit subtle, pink cast.
To understand what is happening, I even tried sampling the pink background cast, then generating a New Image, using that colour sample. This results in a plain image with a noticeable (again, very subtle) pink cast. And if I white balance that image, regardless of the method, the result remains pink.
If I generate a New Image, using the default white and compare the two together either visually or using a colour sample, the difference is obvious. If I zoom into the colour picker(s) and click back and forth between each color sample, one can see the point jump slightly.
Is there a way to "tweak" the white balance tool so a pinkish cast is not the result, especially when I use the pointer? I would prefer to not have to somehow manually compensate each time I white balance.
