Update Available - Version 8.0.402
An update is available to Version 8.0.402 (20-Nov-2023)
Amount controls: when you click on the Amount square at the right of the control, the mask menu that drops down is now initially positioned to the second item. If there is no mask, this corresponds to New Mask… If there is a mask but no mask dialog box, this corresponds to Re-open Mask Dialog Box. If there is a mask but there is a mask dialog box, this corresponds to Reset. These common items are now easy to choose you can just double click on the mask menu to select them.
When launching Picture Window via a command line, if the "exit_when_done" keyword is present, the program will exit after processing the last file in the command line. The Export transformation also has a new item in its settings menu to force its execution when it is run while loading a script or workspace script. These features combined are meant to allow Picture Window to be run from a Windows batch (.bat) file unattended.
Updated to ExifTool 12.70.
