Cloning--Angles seem backwards
Posted: September 18th, 2023, 4:15 pm
by Robert Schleif
When cloning with the square or diamond shapes and using any angle other than zero degrees, while the white outlines of the input and (intended) output are correct, the actual output is at an angle of -x degrees when it should be +x degrees.
Re: Cloning--Angles seem backwards
Posted: September 18th, 2023, 5:35 pm
It seems OK here -- can you post an example?
Posted: September 18th, 2023, 8:18 pm
by Robert Schleif
Just cloned from the black area into the yellow petal area.
Posted: September 19th, 2023, 7:21 am
The problem only shows up depending on the relative positions on the source and target points. Fixed for next release.
