Update Available - Version 8.0.390
An update is available to Version 8.0.390 (18-Sep-2023)
Fixed some problems with automatically restoring control to transformation dialog boxes after using Alt-Mouse Wheel or Alt-Drag to zoom or scroll the image.
There is a so-called feature of Windows that requires you press the Alt key a second time after an Alt-Zoom or Alt-Scroll to restore normal cursor tracking. The same problem with the Alt key affects many other Windows programs including Adobe Photoshop and Premiere. The problem is caused by a somewhat useless feature of Windows, namely if you press Alt and release it, the menu bar is enabled and if you then press a letter key, the corresponding menu item is executed. Fortunately, there is a way to disable this Windows behavior via a freeware program called AutoHotKey in combination with a script that remaps certain uses of the Alt key. Starting with this version, this fix is automatically installed in your Windows Startup folder as the file: Alt_menu_acceleration_disabler.exe. You will need to restart your computer to get it to load the first time it is installed. By default, the fix is enabled, but if for some reason you want to restore the way the Alt key worked before, you can toggle it on or off by pressing both Alt keys at the same time. For more information on this, see the following YouTube video: https://www.youtube.com/watch?v=vRld4bVFrpU.
