Update Available - Version 8.0.387
An update is available to Version 8.0.387 (10-Sep-2023)
Clone Tool: temporarily reverted to previous version without custom brushes as there was a serious problem with the new version.
A number of transformations such as File/New, Resize, Watercolor, Layout, etc. let you enter an image size manually. Accidentally entering a very large number, can cause Picture Window to crash or create a very large, unwanted image. There is now a limit (which you can set in File Preferences as Image Dimension Warning) for manually entered image widths or heights above which Picture Window will issue a warning so you cancel the entry if it was made in error. The default value is 20000, but if you have a limited amount of memory you might want to use a smaller value. If you have lots of memory and routinely work with very large images, you might want to use a larger value.
