Test pattern problems
Posted: August 1st, 2023, 2:21 pm
Hi,
Just noticed this bit of odd behaviour with about half of the test pattern thumbnails.
For the following patterns:
checkerboard; color wheel; cosine falloff; gamma test; gray discrimination; RGB cube; star; step wedge
If you open them and then Cancel via the dialog window, the thumbnail in the browser window persists when you try to close it. If I close and then re-open the browser window the thumbnails disappear. If you open and then OK the settings via the dialog window and then close the thumbnail, the thumbnail disappears.
The rest of the test patterns work as expected.
Thanks.
Mark
Thanks.
Mark
