File open and File save back - undesired filename persistence
Posted: April 23rd, 2023, 4:27 pm
Scenario :
The suggested filename is based on the initial file in the transformation, that is file1, not the latest file opened, that is file2.
Scenario 2 :
Open multiple files and pick different files in the list as indicated by the red dot next to filenames. The same behavior happens.
Suggestion : derive the filename from the currently open file, that is file2.
- Process an image (file1) using File open and a series of transformations.
- Save back the final image using File Save back
- Keep the image transformation tree for the next image.
- Revisit File open and select a different file ( file2 )
- Go to the last transformation in the tree, and save back using File Save back
Scenario 2 :
