I accidentally expanded the "Save Image File" window after clicking on File\Save Back...
It will now occupy most of the screen and will not minimize even though the mouse cursor will change appearance to grab the side(s) or corner(s).
The "Open Image File" also does the same thing and will not minimize.
I removed the program then re-installed it using the v350 msi file to no effect.
v350 - cannot minimize "Open Image File" or "Save Image File" windows
Re: v350 - cannot minimize "Open Image File" or "Save Image File" windows
I assume you are referring to the Windows File Open and File Save As dialog boxes used to select the pathname to open or save.
At least on my computer, there is no maximize or restore button in the upper right corner of these dialog boxes, but you can still maximize them via the system menu in the upper left corner. You can then use this same system menu to restore the windows. In any case, it seems most other Windows programs work the same way.
Got it. Click on the upper left "favicon" of the window will provide a drop down menu for selection.
Thank you... ...den...
