Update Available - Version 8.0.342
Posted: January 7th, 2023, 10:02 am
An update is available to Version 8.0.342 (7-Jan-2023)
Dehalo transformation: fixed problem with amount mask not being applied correctly.
Speck Removal: In Patch Match mode (and only in Patch Mode), there is now a new slider displayed just below the Speck Radius slider called Speck Outer Radius Factor. This slider runs from 1.0 to 4.0 and controls the size of the outer radius of the area in the input image that will be searched for a matching bit of image to clone over the speck. Larger values cause Picture Window to search a larger area to find a matching patch.
