Update Available - Version 8.0.341
An update is available to Version 8.0.341 (28-Dec-2022)
Fixed problem in Combine Channels transformation causing it to crash when it starts up.
Added a new Dehalo transformation to reduce halos in oversharpened images. See the updated help file or Transformations.pdf for details. While it seems to work fairly well, this transformation is still a bit of a work in progress – I hope to improve the halo detection algorithm in the future. You will need to do a full install to get the new help file and a new bitmap.
