Update Available - Version 8.0.336
An update is available to Version 8.0.336 (7-Dec-2022)
All transformations except those that are top level or whose output image size may differ from their input image size now start up with the same zoom and scroll settings as their input image. When you double click to edit a transformation however, the output image is zoomed to fit the available space. Previously only a few of the retouching tools worked this way.
Detail Tool: added a button in the upper right corner of the dialog box to display the blurred input image in place of the output image. This makes it easier to select a Blur Radius appropriate for the level of detail you want to remove.
Batch Operations – if a batch operation runs to completion, the current file is set to the first one in the list. If a batch operation is terminated before completion, the current file is set to the file being processed when the batch process was terminated.
