An update is available to Version 8.0.328 (1-Nov-2022)
Scratch Removal Tool: fixed problem causing random crash when adding new control points.
Removed File/Print Setup command since it is unnecessary and was not working.
Unsharp Mask: fixed problem with threshold slider being redrawn incorrectly when dragging dialog box from one monitor to another.
Mask lasso tool: temporarily removed out of bounds checking since it was not working when the image was zoomed it.
Update Available - Version 8.0.328
Re: Update Available - Version 8.0.328
Problem with printing.
With older version <Ctrl P> opened the system dialog to select an configure a printer.
After this the PWP-Print-dialog ist opened, but cannot work because of missing info.
Clicking ok causes a crash.
