Update Available - Version 8.0.324
An update is available to Version 8.0.324 (14-Oct-2022)
If a transformation only takes control over one half of a split screen display, the other half can now be zoomed or dragged without holding down the Alt key.
When loading a script or workspace script file and trying to open a file that no longer exists, you now have the option of editing the pathname directly. This is useful if you have, for example, renamed the folder containing the image file and just want to edit the name manually instead of selecting the file using the Windows File Open dialog box.
Fixed problems with Texture, File New, and Size to Fit transformations not always updating correctly to changes in the size or type of their Reference Image.
Spiral transformation: added checkbox to freeze the edges of the output image.
Updated to ExifTool 12.48
