Spiral transform : keeping the edges in place? as twirl / swirl effect
Is there a way to create a spiral variant (twirl), whereby central pixels along the image frame are un-twisted ?
In other words, the spiral effect is neutralized on the midpoint along the image sides.
For an example see Photoshop's twirl dialog box :
( as presented in from https://www.photoshopessentials.com/pho ... rt-effect/
Re: Spiral transform : keeping the edges in place? as twirl / swirl effect
You can do this with the Displace transformation by creating a mask for the rotation angle the starts out white in the center and fades to black at the edges.
This Spiral transformation, if the radius stays in-bounds in the image, will leave the edges untwisted, but the effect is abrupt.
Very interesting use of the mask.
Could the displace transform accept other displacements such as spiral and its variants ( solid, linear, hyperbolic, logarithmic ) ?
If the maximum amount of rotation in Displace were not limited, you could use a mask to simulate other types of spirals by playing with the rate of falloff from the center to the edge, but I don't think this is a good direction to try to go in since this would be hard to control.
