Update Available - Version 8.0.322
An update is available to Version 8.0.322 (8-Oct-2022)
File Export command and transformation: if you opt to export as a specific file type and then click the button to select the default file save options, the tab for the selected file type (if any) is now automatically selected.
Mask freehand tool: modified to try to avoid wrap-around when drawing outside the image in some cases.
Fixed problem causing crash when saving script files via the Script/Save As command.
Clone tool: fixed problem causing input image display not to update in some cases when selecting a new source image.
