Update Available - Version 8.0.321
An update is available to Version 8.0.321 (21-Sep-2022)
Crop and Warp now number their 4 control points. Similar to Composite and Level, you can recenter the display on a control point by typing its number on the keyboard. Typing the same number multiple times zooms the display each time.
Level now works consistently with Crop, Warp and Composite in that typing a number multiple times zooms the display each time. Fixed problem in Composite causing the number keys to remain active when only the output image is being displayed.
Updated to ExifTool 12.45.
Closing the File/Preferences dialog box now closes Font and Theme dialog boxes if they are open. Added Verdana to the list of available UI fonts.
Re: Update Available - Version 8.0.321
Wow !
