Update Available - Version 8.0.295
Posted: May 28th, 2022, 7:58 am
An update is available to Version 8.0.295 (28-May-2022)
Image Info: fixed problem causing Date Taken to display the wrong month in some cases.
Transformations with dual Amount sliders (currently only Brightness Curve, Color Curves, Mobius) now gray out the lower (black) Amount slider if the corresponding settings have no effect on the image. Since this is the default initial condition, it grays out the black slider on startup. As soon as you make a change to the black settings, the black slider is restored.
Mobius transformation: fixed problems with 48-bit color images when used with a mask.
