Watercolor Preview Pane Problems
jfoster
Post by jfoster »
In the Watercolor Transformation, the "Display Input" Preview Pane displays the processed preview. Also, if the transformation is re-sized while the Display Input option is selected, the Preview Pane goes blank.
Re: Watercolor Preview Pane Problems
Since, unlike most other transformations with previews, the input and output images are generally different sizes, so the preview only shows the output image, so that is normal. Otherwise, since the two images are different sizes, they will not line up when both viewed at 1:1. The display buttons therefore only affect the main image area and not the preview.
I have fixed the problem of resizing the transformations while the input image is being displayed.
