Update Available - Version 8.0.289
Posted: May 22nd, 2022, 7:12 am
An update is available to Version 8.0.289 (22-May-2022)
Watercolor: fixed problem causing a blank preview after a Reset and problems with dragging the preview area to scroll it.
Multipass Sharpen: fixed problem causing preview to sometimes show an incorrect result depending on which passes were enabled.
Zero-Centered Amount Controls (e.g. as used in the Brightness and Saturation transformations): fixed problem of double-click not resetting the Amount slider correctly.
Advanced Sharpen, Denoise, Gaussian Blur, High Pass, Linear Blur, Multipass Sharpen, Precise Gaussian Blur, Unsharp Mask: fixed a number of problems related to the preview area displaying incorrectly and click and drag not scrolling the preview correctly in some cases. The 2:1 preview buttons are now only applied while you hold the button down. When you release the button, the preview reverts to 1:1.
