Problem with Monochrome transformation with dual monitor
Posted: April 15th, 2022, 4:26 pm
Jonathon -
1st - Thanks for your wonderful program and the responsiveness to questions and concerns!
2nd - I'm seeing a possible bug with the Monochrome transformation on my dual monitor system.
I've set the Method to be filter, and the Filter Color picker pops up just fine on my secondary monitor
on top of the image I'm editing. I see the Filter Color menu correctly with the color cube clearly
visible. I then drag the Filter Color dialog box to the left over to me primary monitor. As the dialog
box transitions over to the 'new' monitor everything looks fine UNTIL the dialog box is fully on
the primary monitor. At that point, the color cube disappears except for a sliver of the very left
(blue..magenta) edge of the cube.
I'm running Windows 8 if that makes any difference.
Thanks!
John P
Thanks!
John P
