Update Available - Version 8.0.280
An update is available to Version 8.0.280 (20-Mar-2022)
Readout Mode: fixed problems with the display of long captions – they now scroll horizontally.
Raw Develop: fixed problems with processing monochrome files using a camera with a color profile.
Added a 2023 Moon Phase Calendar to the Downloads page of the web site.
Fixed problem causing crash when passing multiple files to PWP from FastStone using its Edit in External Program command.
Hot Spot transformation: fixed problems when using a custom curve and dragging control points that are very close together. Incidentally, I recently discovered this transformation can also be used to remove circular lens flare spots caused by shooting into the sun.
Re: Typo in hotspot help
" Most lenses have a considerably nsmaller and less obvious hot spot."
