An update is available to Version 8.0.261 (16-Dec-2021)
Guided filter: implemented fast guided filter for radius > 3 which speeds up the calculation somewhat. The speedup is even greater if radius > 7.
Preview Tool: if the image being previewed changes size, it now does a zoom to fit. Otherwise, the current zoom and scroll values remain in effect.
Brightness curve: eliminated unnecessary recalculation of the mean image in some special cases.
Brightness Curve, Multipass Sharpen, Add Texture: fixed problem causing Cancel not to correctly restore the initial settings when requested.
Fan: added rotation angle control in Full Circle mode.
File Open: you now get an error message if you try to delete all the files in the file list.
Curve control: the current control point on the curve is displayed as a square instead of a circle.
Update Available - Version 8.0.261
Re: Update Available - Version 8.0.261
Excellent update - thank you
