Mask from texture detection : lower and higher limits
In the advanced sharpening tool, there are lower and higher limits for defining the textured areas:
Histogram
The histogram display just below the Sharpen Amount slider lets you perform selective sharpening by including only those neighbor pixels in the computations that differ by more or less than a given threshold amount from the pixel you are sharpening. Raising the lower limits helps prevent amplifying fine texture or noise. Lowering the upper limits helps reduce halos
It would be useful to have the same controls in the masking tool.
Pierre
