Update Available - Version 8.0.219
An update is available to Version 8.0.219 (30-May-2021)
Removed help button from white screen display.
Right-click menu for Image Browser: added item to access Favorites as a submenu. Also you can now use either / or . as a keyboard shortcut to bring up Favorites.
Fixed problems with various transformations not always restoring the hand cursor when closed with color pickers open.
Transformations.pdf – added info on warming images using the Color/Primaries transformation.
The horizontal/vertical split screen setting is now preserved across sessions.
