improvement request: Launching image compare from the image browser
In the image browser, add item to the drop down list when right-clicking an image:
The "Compare image" item would launch the image compare transformation
Also consider the ability to launch the "image compare transformation" by when two images are selected, then launching image compare would populate images A and B.
Re: improvement request: Launching image compare from the image browser
For what it's worth, you could use Quick Pick by pressing 'c' - to list subset of transformations including Compare, which if used often, should be on top of the list. Also, there is a Favourites button, where you could add Compare by hand.
tomczak wrote: May 19th, 2021, 4:00 am For what it's worth, you could use Quick Pick by pressing 'c' - to list subset of transformations including Compare, which if used often, should be on top of the list. Also, there is a Favourites button, where you could add Compare by hand.
Thanks for the tip.
