Workflow auto-close widget transformation dialogs
Just discovered an ergonomic trick when checking widget settings in a workflow: if I open a widget transformation dialog and change nothing, I don't have to explicitly close it before moving to the next widget; it's enough to click on the next widget, which closes previous dialog and opens a new one. Much less work inspecting longish workflows.
Re: Workflow auto-close widget transformation dialogs
Yes, you can just click the next widget to close the current one.
This works even if you have changed something. Clickinng the next widget does an automatic OK in the widget that is opened.
