? Maybe make Multipoint Gradient responsive to input image changes?
dimockn
Post by dimockn »
Hi
Re version 8.0.202
The Multipoint Gradient Help correctly says..
... A Match Input Image checkbox is also displayed; when this checkbox is selected, the color associated with a given point is automatically made to match that of the corresponding location in the input image WHENEVER YOU REPOSITION THE POINT.
I have images of some old etchings on paper that has discoloured. Thumbnails of two of them are attached. The discolouration varies from image to image, and it varies gradually across each image.
I can use Multipont Gradient with four points in the image margins to get a gradient to use for a graduated 'white balance' for the first such image.
But if I select a second image as input, the resulting gradient does not change, so I would need to go in and wiggle each of the four points to get the right result.
So, please consider changing Multipoint Gradient to be responsive to such input image changes?
Best regards, and thank you for a magical product!
N
Locks on the Rideau Canal (1)-1.jpg (32.88 KiB) Viewed 2337 times
Timber Slide at 'Les Chats' (Upper Canada)-1.jpg (34.66 KiB) Viewed 2337 times
Re: ? Maybe make Multipoint Gradient responsive to input image changes?
dimockn
Post by dimockn »
FANtastic :-)
