Update Available - Version 8.0.160
Posted: September 30th, 2020, 4:13 am
An update is available to Version 8.0.160 (30-Sep-2020)
Fixed problems with un-bypassing bypassed transformations saved in scripts after the script was reloaded.
Fixed problems when saving or exporting image files, the associated script file (if any) was being saved without the image file extension. For example, the script for a.tif should be named a.tif.script, not a.script – this is necessary since the same file might be saved with scripts in two different file formats which would overwrite one of the script files. I’m not sure when this started happening or why I changed it and possibly something else will stop working correctly as a result.
