Update Available - Version 8.0.159
Posted: September 29th, 2020, 9:32 am
An update is available to Version 8.0.159 (29-Sep-2020)
Oval Gradient Mask Tool: now supports rotated ovals similar to the Gradient transformation. It also now preserves the center location when you resize the oval.
Re: Update Available - Version 8.0.159
Posted: September 29th, 2020, 10:39 am
I can rotate oval by entering the Angle value. Is there a mouse-drag shortcut to it?
For instance: in Crop Shit-left mouse would rotate it. In Oval Gradient Shift-left mouse seems to to set both oval axes to the same value (i.e. circle).
Posted: September 29th, 2020, 10:46 am
In both the Oval Gradient transformation and the Oval Gradient mask tool you rotate by dragging the line that extends from the center of the oval. Holding down Shift when dragging any of the other control points makes the gradient circular.
Posted: September 29th, 2020, 11:19 am
Yes. Got it. Cheers!
