Update Available - Version 8.0.152
Posted: September 19th, 2020, 8:05 am
An update is available to Version 8.0.152 (19-Sep-2020)
Fixed problem with transformations not propagating changes if they were set to display only the input image, saved, re-opened for editing, modified and then OK clicked.
Adjusted location of status display so it does not get overwritten by progress indicators.
Levels and Color: reworked to fix structural issues with the previous implementation. It now produces results more or less identical to Color Balance when doing Auto White Balance, and it also works predictably when applied to different images. The previous Color Balance control has been replaced with Remove Color and Add Color controls similar to the way Color Balance works. It should still work with old scripts since the old Color Balance color is mapped to the new Add Color and the new Remove Color defaults to white. If you want Levels and Color to auto white balance, you set Color Balance to Auto White Balance -- this will white balance the current image and all subsequent input images. To white balance only the current image, you then set Color Balance to Custom, at which point subsequent images with color balance consistent with the current image and not be rebalanced. Similarly with dynamic range which can be Custom, Reset, or Full. Custom means the markers stay in the same place for subsequent images. Reset means the markers are set to align with the tic marks for subsequent input images and Full means the markers are set to pure black and white for subsequent images.
