Update Available - Version 8.0.129
An update is available to Version 8.0.129 (11-Aug-2020)
Added a tool bar at the top of the main window to select horizontal or vertical split screen. The tool bar is grayed out unless the screen is split.
File Preferences: removed autosave setting – autosave is now always on.
When restarting after a crash or some other abnormal termination, PWP now asks if you want to load the last autosaved workspace.
Mask: Save/Combine (from the settings menu) now ask if you want to finalize any pending operations. Also fixed problems with rebuilding saved/combined masks.
Re: Update Available - Version 8.0.129
... looks like the horizontal and vertical button bmp files didn't make it in the download. Errors encountered when opening PWP.
Sorry -- will upload a new version shortly.
In the meantime, the two missing bitmaps are attached -- just unzip them and copy to My Documents/Picture Window Pro/Bitmaps
Bitmaps.zip
(2.55 KiB) Downloaded 204 times
Oh. cool. Thanks that saved a few minutes. Looks good and functions well. I can see this coming in handy from time to time.
(Update) Seems like there is now some extra line space under the toolbar, or am I forgetting how it looked before?
Fixed spacing issue for next release.
