Update Available - Version 8.0.124
An update is available to Version 8.0.124 (31-Jul-2020)
Frame: fixed issues with defining frames using custom images in upper right and lower right corners.
File/Preferences: removed option for web-based help. HTML Help which is built into Picture Window can be zoomed by holding down the Ctrl key and adjusting the mouse scroll wheel. Web-based help will no longer be updated although I will leave a copy of the current help files in place for a while until everyone has a chance to update to a more recent version of Picture Window. The PDF version of the help file will remain available and will be updated going forward.
Export Transformation: if Save To is set to Clipboard, the Write File button becomes Copy File and clicking it copies the exported image to the clipboard.
When saving script or workspace script files, the order of the top-level branches is now recorded in the file. If this information is present when opening the saved script or workspace script, the original order of the top-level branches is now restored. With previous versions, the order of the top-level branches was not recorded or restored. This difference is cosmetic since the order of the top-level branches is arbitrary, but it can be confusing if the workspace comes back looking different from when you saved it.
