Update Available - Version 8.0.111
An update is available to Version 8.0.111 (15-Jun-2020)
File Preferences: increased maximum text delay to 5 sec.
Lines/Arrows/Text Tool: fixed problem with the text control not updating when switching among lines. Fixed problem with crash in some cases when text control was closed via its close icon.
Added a new File Save (and File Export) options to allow including a workspace script (with image names or with image copies) when saving or exporting files. You can set this as a default option in File Preferences or specifying when asked at the time the file is being written. These options are intended to deal with the situation where your workspace may include several versions of the same image or possibly multiple images and you want to save one of them but also want to retain the option to regenerate the others at a later time. For example, you may have an edited image cropped several different ways for different uses or resized to several different resolutions, depending on whether you intent to print it, view it as screen wallpaper, post it on the web or email it. If you include a regular script, just the transformations needed to regenerate the current image are saved and the transformations needed to regenerate the other versions of the image are not saved.
