Reboxquests for crop command
Posted: June 6th, 2020, 7:41 pm
by johnp
Jonathon -
Many thanks for such a fine product. I have two requests for the crop command
a) When I specify a custom crop, the tab key does not move to the next size
Re: Reboxquests for crop command
Posted: June 6th, 2020, 7:44 pm
by johnp
Let me try again...
Two request for the crop box
a) The tab key does not advance to the next field for the "custom" mode
b) I wish it would remember my last custom crop size.
Thanks!
John P
Posted: June 6th, 2020, 9:05 pm
Thanks for the suggestions,
If you select Save as Default from the settings menu, the custom crop size will be initialized to the current settings the next time you use Crop.
If you select Reload Last Settings from the settings menu (or use the Ctrl-R shortcut), the custom crop size from the last time you used Crop will be used (along with all the other settings).
I could support tab and back-tab in the Crop dialog box, but there are many other dialog boxes with the same issue which, to be consistent, I would also have to change.
Posted: June 7th, 2020, 5:42 pm
It turns out there were a limited number of places where a dialog box has multiple edit controls, so I was able to add support for tab and shift-tab most of them, for the next release.
