Update Available - Version 8.0.104
Posted: June 1st, 2020, 6:56 am
An update is available to Version 8.0.104 (1-Jun-2020)
Speck Removal Tool: speeded up Patch Match by using multiple threads.
Export: added status display during file save operation.
Selective Color Correction: fixed problem causing slight color shift when displaying modified color wheel and potential overflow problem when making large brightness changes to 48-bit color images.
Added new Hue Saturation Control (see updated help and pdf files) for use in Monochrome and Mask (see below).
Monochrome: added a new conversion method: Hue Saturation. This lets you lighten or darken the result by placing control points on the color wheel.
Mask: added a new mask tool: Hue Saturation. This uses the same new Hue Saturation control as Monochrome to let you create masks based on hue and saturation by placing control points on the color wheel.
Mask: fixed problems with dragging the Mask dialog box to a second monitor.
