Clipped Pixels and Shadow Threshold
Posted: March 22nd, 2020, 7:29 am
It looks like Settings/Clipped Pixels/Shadow Threshold for both colours is always taken as zero irrespective of the value entered. Highlight threshold seems fine.
Re: Clipped Pixels and Shadow Threshold
Posted: March 22nd, 2020, 7:47 am
Not seeing this here - how are you testing? I tried it with a step wedge.
Posted: March 22nd, 2020, 8:07 am
Can you try it on this image? The shadow threshold is set to 5.
Posted: March 22nd, 2020, 8:35 am
Not sure if the patches are just mislabeled or if JPEG compression is messing with them, but the labels do not correspond to the actual readings from the readout tool.
Posted: March 22nd, 2020, 8:54 am
I think I know why: you use AdobeRGB working colour profile and you saved and reopened the file, automatically converting it to the working colour space. It's the straight line at the beginning of sRGB Gamma curve. Try not converting it or turning the Colour management off.
Posted: March 22nd, 2020, 9:26 am
It turns out what the clipping indicators are showing is based on the image being displayed on the monitor and not on the underlying image data. The monitor data has been converted to the monitor color space so it clips slightly differently from the image. I'm not sure how easy this will be to change, or even if it should be changed, but I'll take a look.
Posted: March 22nd, 2020, 9:44 am
Cheers!
Posted: March 22nd, 2020, 10:04 am
A related question: does it mean that the Readout Tool still shows the image data?
Posted: March 22nd, 2020, 10:22 am
Yes, the readout tool should be OK.
For the next release, I fixed the highlight and shadow clipping to reference the zoomed underlying image instead of the color managed version.
