Update Available - Version 8.0.69
Posted: March 21st, 2020, 10:57 am
An update is available to Version 8.0.69 (21-Mar-2020)
Color Picker: added a new menu item to the end of the settings menu to save the current color space (RGB/HSV/HSL) and units (percent/decimal/hex) as the readout defaults used when a new color picker starts up. These defaults are saved between sessions.
Mask: fixed problem with Mask Paint Tool brush settings not being restored correctly from a default mask settings file.
Re: Update Available - Version 8.0.69
Posted: March 21st, 2020, 11:31 am
by jfoster
Don't know if this is a timing issue but, Check for Update on version 8.0.68 says it's the latest version while Check for Update from 8.0.69 claims that 8.0.68 is the newest version.
Posted: March 21st, 2020, 1:17 pm
The correct version info is on the web site -- Windows is probably cacheing the old version info on your computer. If you clear your browser cache it may re-sync.
