Keyboard shortcut for Slider Control
Posted: March 14th, 2020, 7:33 am
Sometimes I'd like to keep looking at the image and see the slight changes as a Slider Control is adjusted with a mouse. I can't figure out a way of doing it with e.g. left/right arrows or some other keyboard keys when the slider is in focus.
I'm not sure how easy (or more likely difficult) it is to implement something like this, but I would find it useful to be able to adjust sliders with some keyboard combination - using the mouse if fine most of the time, but I have to move my eyes from the image to the slider to see what I'm doing, and by doing it I often miss the mark (e.g. when trying to find the real gamma of the monitor when using the new Gamma 2.2 test image, and there are some other cases).
Re: Keyboard shortcut for Slider Control
Posted: March 14th, 2020, 7:38 am
Sliders never have focus unfortunately, so there is no way to direct keystrokes to a particular slider in a dialog box.
If you hold down the Shift key, sliders adjust by 10X smaller increments if that's any help.
Posted: March 14th, 2020, 7:44 am
Ok, thanks.
I'll try one more idea then: to move a slider (with or without Shift), the mouse has to hold it and drag it. If I click on the slider scale on either side of the slider, the slider moves to the point I clicked on.
Would it be possible to have an option (e.g. slider with Ctrl or such) that would make a slider to move just a little in the direction of the mouse click? This way I wouldn't have to really look at the slider and keep clicking while looking at the preview.
Posted: March 14th, 2020, 7:46 am
That could work.
Posted: March 14th, 2020, 10:31 am
Awesome! Thank you!
Posted: March 15th, 2020, 2:05 am
I may be pushing my luck, but would it be possible for the new Ctrl-click slider behaviour to rub off on the Brightness Slider in the Colour Picker as well?
One of the reasons I'm asking is that when I was trying to use Checkerboard to create Black Point and White Saturation test images, it is fairly difficult to adjust the brightness of one of the colour patches by a small amount (e.g. one pixel value). It could be done manually, by typing in the numbers, but since nominally a checkerboard can produce a colour image, I need to change 3 values in the Colour Picker.
https://www.jonathansachs.me/phpbbBB3/v ... f=4&t=2455
